BrokenTiller
Hi, I am a home owner with just under 1/2 acre lot that is sloped decently (walk-out basement, first floor 2 steps up from ground level at the front door and ground slopes downward across the back yard). The front yard is small and tight with flower beds, sidewalks, etc. The back yard is much larger and more open. Currently, I have a John Deere Hydro 175 tractor that I bought used off Ebay for $401 about 7 or 8 years ago and small cheap MTD push mower that I bought used for $75 2 years ago. I push the front yard and around the house to trim along the sidewalk and patio around back, and then I use the rider for the rest of the back yard and side yards. I feel like I have already gotten more than my money's worth out of the tractor, and I am beginning to prepare for the reality that I'll have to replace it at some point in the next few years.
So, as is my typical practice, I've already started thinking about what I'm going to want to get loooong before I actually need it. I don't love the idea of getting a 'standard' push/walk behind mower with a 21" or 24" cut because the back yard is so open that it begs for something a bit bigger that can cut my time mowing down significantly, but I like the idea of consolidating to a single mower for my entire property and freeing up some space in the shed for more tools/toys. I've seen a couple of bigger push mowers approaching a 30" deck, but I'm not sure if they'd really be maneuverable in the tight areas in the front yard (there is enough space between flower beds for me to mow it with my tractor, but it takes longer than mowing it with the small walk behind because I have to do multiple laps to catch all of the little areas or stop and back up repeatedly with the tractor) due to its general 'clunkiness'. I've also seen some of the bigger walk behinds with 'pivot' wheels on the front, but they seem to generally be more commercial grade models that I've seen (I've only ever seen them being used by landscapers) and I'm not sure how maneuverable they really are.
Do the people here with more experience and knowledge than I have any thoughts or recommendations of brands/types of mowers that I should look into?
Thanks!
Thanks!
