impalass
When you had the carb off did you the reeds. With both carbs you have the same symptoms. Are the filters clean, you might two, one in the gas tank and the other in the carb. Depending on which carb you have one is in the inlet supply which is a small wire mesh tube and the other in the carb over the main jet.
When you cleaned the carb did you take out the main jet and checked the holes were clear. You have a very small hole near the top of the main jet.
