Two-Stroke
- May 7, 2010
- 23
- 1,594
I watched your video and I can tell you that my problem is nothing like that. Mine appears to be a lean condition but I can't tell from what. As of today I've changed both crank seals, changed the carburetor from a LB that was running fine, checked the block for leaks visually only (maybe I need to rig up a crank pressure tester) and still the engine runs wide open. I looked at the carb while it was running and the governor has the carb butterfly closed. I'm almost to the point of buying another mower and using this one for parts.
I think there must be a fairly significant leak for it to run fast with the butterfly closed. Keep in mind that, unlike a chainsaw, a rotary mower has a fair amount of drag (even without any grass underneath) due to the power necessary to turn the blade -- it's like a propeller.
The fact that it does this with another carb (that you know is good) is a real puzzler.
You are sure that the butterfly is closed when it's revving high -- correct? That's the most baffling part. :confused2:
