R revese Forum Newbie Jun 2, 2013 #1 Replace drive belt on the mower. When I started the mower put it in forward gear and went backwards. Put it in reverse and went forward. Pease HELP
Carscw Lawn Pro Jun 2, 2013 #2 revese said: Replace drive belt on the mower. When I started the mower put it in forward gear and went backwards. Put it in reverse and went forward. Pease HELP Click to expand... I may be crazy but you put the belt on wrong. You have pulley that are flat with no deep grove make sure the flat side of the belt rides on them (( racing is the only sport that you need two balls ))
