removing engine 5021 bricktop
bricktop
how do you remove the engine on a 5021 lawnboy
Briana
Welcome to LawnWorld!
I moved your thread to the Small Engine & Mower Repair forum. :smile:
impalass
This is a lawn boy engine so i think you should move it back.
WhyZed
I think you better grab a beer and sit down after the bouncing-around you've taken! I've have less bumps getting some from a happily married woman!
You are in the right place now.
The engine comes off from under the deck! :thumbsup:
oldboys
First, remove blade assy. When taking off blade collar, strike corner of collar with hammer in direction of crank rotation to break taper. Once blade and collar are off, remove muffler. Once muffler is off, remove 3 bolts and nuts that secure engine to muffler plate. Thats it.
robinb66
Actually the engine mounting bolts are on the outside of the muffler, the only time you need to remove the bottom muffler plate is to take the engine mounting plate off!!:thumbsup:
