cub cadet 3205 carb question
JB61
The pilot air screw that is near the bottom of the carb. Is this screw supposed to be screwed all the way in?
WELCOME to these Forums...
No ... not all the way closed, at idle you should find a point between closed and 1 1/2 open, where it idles best... :smile:KennyV
Thanks for the Welcome !! If I open it even 1/2 turn it leaks gas out. Suggestions?
