Everyone seems to obsess over the hours on a tractor. With that in mind, when bagging a large 3 acre property is it better to let the engine idle while emptying the bags (8 or 9 times for grass (more for leaves)) or turn the tractor off each time ? Turning the tractor off each time would save a little bit on the hour meter but maybe cause the starter to fail sooner ?
