Two-Stroke
I just bought a lawn boy mechanic's book and it says that you should only use lawn boy 2 cycle oil, not generic 2 cycle like Sears, etc. Is there that much difference in quality? What are you all using?
I use Poulan oil at 50:1. The newer oils are better -- the technology has improved a lot in 20 to 30 years. I haven't had a problem with that higher ratio.
I'm always skeptical of any company promoting its own product in a manual. And I'm a huge LB fan.
