Rpmz711982
Hello, I've got a 21hp huskee riding mower that dies when you engage the deck. The idler pulley was bad but I changed it an mowed just fine. Did an oil change an new plugs an now it's doing it again. Any suggestions?? Thanks
Most likely cause is a bad safety switch. most likely the seat switch, or the wiring associated with it.
