Series 115 Mower,no start.
Kev7274
My 115 series riding mower doesn't want to start. The battery was bad so I replaced it thinking that was the problem.It wasn't.
I can take a screwdriver and jump the starter solenoid it starts ok. I checked the fuse and it was ok also. Not sure what I need to start checking or testing to see what may be wrong. Any ideas? Testing procedures,etc. I'm thinking it''s the solenoid.
chance123
Chec your ignition switch that all the wires are connected
After checking the ignition switch, this procedure may help you go farther if that is not the problem.
Electrical* problems can be very easy or very difficult, depending on four things.
1. * How well you understand basic electricity.
2. *What tools you have and know how to use.
3. *How well you follow directions.
4. *You don't overlook or assume anything and verify everything.
Remember we cannot see what you are doing. *You are our eyes, ears and fingers in solving this problem. *You must be as accurate as you can when you report back. *The two basic tools we will ask you to use are a test light and a multi-meter. *If you have an assistant when going through these tests it would be very helpful. *These steps work the best when done in order, so please don't jump around. *Now let's solve this problem.
First, check the fuse(s), check battery connections for corrosion (clean if necessary) and *voltage - above 12.5 volts should be good.*
Second, check for power from the battery to one of the large terminals on the solenoid. *One of the wires is connected directly to the battery and has power all the time so one of the large terminals should light a test light or show 12 volts on a meter at all times.*
Third, *check for power at the small terminal of the solenoid while depressing the clutch/brake pedal and holding the key in the start position (you may need an assistant to sit in the seat to override the safety switch). If your solenoid is a four wire solenoid, check both small wire terminals as one is ground and the other is power from the ignition switch. *If your solenoid is a three wire solenoid, make sure the solenoid body is not corroded where it bolts to the chassis of the mower as this is your ground path back to the battery. *If in doubt, remove the solenoid and clean the mounting area down to bare metal. *If there is no power to the small terminal then your problem is most likely a safety switch, ignition switch or in the wiring.*
Fourth, check for power on the other large terminal of the solenoid while holding the key in the start position (you may need an assistant to sit in the seat to override the safety switch). *If you have power what is the voltage?
Fifth, check for power at the starter while holding the key in the start position (assistant again). *If you have power what is the voltage?
Sixth, check your ground circuit back to the battery.
After you have gone through each of the above steps, let us know what happened when you did each step. *At that point we will have great info to tell you how to proceed. *Remember you are our eyes, ears, and fingers, so please be as accurate as possible.
Be as specific as possible with voltage readings as this will help diagnose your problem quicker. *If you do not know how to perform the above checks, just ask and I will try to guide you through it. *Youtube also has some videos and as you know a picture is worth a thousand words.
Kev7274
All looks ok. 13.06 volts
Ok,13.06 volts
Ok,13.06 volts on terminal.
0 volts with key in start position.
0 volts at starter.
All is ok.
That tells me you have a bad solenoid, which needs to be replaced.
Kev7274
Solenoid didnt make a difference,still wont start.Whats next?
Do you have the two big terminals, and two small terminals or just one small terminal. If one small terminal that it could be a bad ground at the solenoid. if two small terminals could be a safety switch. the four terminal solenoids normally have the safety swithes on the other small terminal, and you will still have power to the other small terminal in the start position.
Kev7274
I have two big terminals and two small terminals. I don't hear anything clicking,there is a relay also near the solenoid.
