B beretta22 Well-Known Member Joined Aug 25, 2022 Messages 119 Jun 23, 2024 #1 Got a ZTX5 with squeal with blades engaged. You can hear it slow down as rpm’s lower to stop. Can’t tell if it’s idler or spindle. Only has 60 hrs on the mower. Just wondering if there’s an issue with any of these parts that’s prone to failure.
StarTech Lawn Royalty Community Leader Joined Feb 19, 2020 Messages 14,553 Location Pluto Jun 23, 2024 #2 It can be a bearing in either the spindle or the idlers. Just something you have determine yourself as you are the one at the mower. Now the spindle do have 6206-2RS bearings if the need replacing and one oil seal.
B beretta22 Well-Known Member Joined Aug 25, 2022 Messages 119 Jun 23, 2024 #3 I’ve tried. Best I can tell it’s the right outside spindle. Still has warranty so I’ll probably take it in. Thanks Last edited: Jun 23, 2024
B beretta22 Well-Known Member Joined Aug 25, 2022 Messages 119 Jun 23, 2024 #4 6206-2RS. Mine has the sealed bearings I think. No grease fitting Last edited: Jun 23, 2024
B beretta22 Well-Known Member Joined Aug 25, 2022 Messages 119 Jun 28, 2024 #5 Warranty replaced two spindles today. I complained about the loud deck from the start. Guess it progressively got worse.
