Grimlock
- Jun 14, 2020
- 6
My charge pump oring was leaking so I had to take the cover off and replace it . I replaced the oil while I was at it . I filled the trans through the fill port on the side and filled the resovoir to cold level . At first I had nothing then I tried flipping the charge pump cover 180 and then tried purging again and started to get movement . The only thing is it only moves at half throttle or less . When the throttle gets above that it stops . I’ve purged it a number of times and have had it on the ground and in the air . With the tire on and it on the ground the unit will move with me on it , but above half throttle it won’t budge . Any ideas ? The unit had zero problems before i changed the oring . Any help is greatly appreciated.
