Zero Turn Mower
edd
the one i had was used commercially for 4 years .....they are good mowers......didnt say how much he wanted to spend..........used commercial wont have any warranty ........speed? timecutter is just as fast as an entry level commercial......
I do not intend to cut all of it with a ZTR. I have a Massey Ferguson tractor and Rhino 72" cutter to cut what is not used for yard and what the hay cutter does not cut. Sorry, I did not intend to leave the impression that I was going to cut it all with a ZTR.
My plan is to take a day this week and search my area for what is available locally. I do not want to buy one out side of my local area (max. 50 miles) I, also, want to be able to buy parts and have it serviced locally. Although I may have to wait a week to search, cause this plan is set up for the benefit of my bride (I don't know her plans for this week).
Mule
A_tank96
Thanks to all of you who have responded. Your input has helped.
Mule
If you are going to mow 30 acres a week, I wouldn't spend under 10k. A toro timecutter would be scrapped incredibly fast on 30 acres. I would start with Grasshopper, Toro, or Scag Commercial models. Kubota would also be a good bet.
Aaron
clpolcar
Get a ferris. I would get one with a diesel engine. It will last longer that a gas engine.
djdicetn
That is if you can afford diesel fuel....it has gotten so much more expensive than regular gasoline it would be a major purchase option decision for me. My father-in-law has a 35 foot Class A motorhome that is diesel and I won't tell you how much it costs for them to travel any distance in it(at 2-4mpg). IMHO, the longevity wouldn't offest the cosdt over ownership of a gasoline powered ZTR. Besides, the other components on a ZTR will usually start to go south long before the engine.
Well, we looked at local options today.
The Kubota dealership will deliver one in the morning. ZD331RP-60R.
Thanks for all of the suggestions and opinions based on your actual experience.
Mule
jekjr
Mule
I have 330 hours on my ZD 326. It has been run under brutal conditions most of those hours. I would definitely go with the Kubota. ZD in the 300 series.
You won't go wrong.
djdicetn
Mule
That was quick and painless:0)
I think that Kubota will get the job done for you!!!
