Hello, I live on 6 acres, but only about 2.5 of it is cleared. May end up being around 4 cleared acres in the next year or two. I have a pond, lots of trees, a couple sheds to mow around. Also, a small portion of the yard is fenced in for my dogs. I have a JD 100 series lawn tractor right now and it is just too small and slow. I am going to upgrade to a Zero turn in the next few days, and want to get some pro oppinions about my choices.
I have it narrowed to three brands based on the two dealers in the area.
Anyway, my choice is between the Dixie chopper Zee 2 with 48" deck, the husqvarna RZ5424 with Kawasaki engine, or a gravely of some type. I havent checked out the gravely's yet, but the one time I was in the store they were less than inviting/borderline rude. This really makes we want to just go with the other dealer and eliminate gravely, but will consider if they are that much better.
Pretty much what I want to know is, for residential use are the DC and Gravely's worth the extra $$. I want to buy something that will last for many years, but dont want to pay more than I need to. The DC zee 2 was well over 4 grand, while the husqvarna RZ5424 with the kawasaki has a larger deck, and is only $3200. I dont want to buy used because im not very mechanically inclined, and if there were issues I'd end up paying for it to be fixed.
Also, I do tow a dump cart behind the mower a lot and sometimes it is loaded with a few hundred pounds. DC is the only one with a towing capacity listed.
Any and all info is appreciated, and thanks in advance!
