hackney502
- Apr 30, 2020
- 2
- 4
I posted this on the simplicity forum, but didn't get any replies. Thought I'd try here.
I have a simplicity champion ZT-20H 50" mower. The left wheel does not pull as good as the right wheel, especially when turn right up a very slight grade. Seems to get worse after mower warms up. I've checked all the linkages (they seem ok), replaced the drive belt and made sure it is installed correctly, checked the fluid level ( ok), tire pressures ok, . Both wheels seem to be spinning at the same speed when jacked up. Have not changed hydro filter yet. Any suggestions? Thanks
