Hello,
I am an absolute amateur at engine repair but I do know my way around them. I recently acquired a Cub Cadet 54" mower with a seized motor and have been trying to fix it. I drained the motor sprayed a bottle of PB Blaster in and got the motor unlocked after a few hits of a hammer on a breaker bar. I have been unable to start the motor so I started back tracking the fuel line and ended up replacing the vacuum fuel filter. I was still not getting any gas pushing to the carb after turning the key so I bought a compression tester today and after connecting I am getting zero compression out of either cylinder.
I am looking for suggestions or next steps.
Thank you so much for any help you can provide.
-Brian
-Brian
