ZD21 fuel level sensor
ghost1
I replaced my sensor with an aftermarket one. The gauge works because when I ground the signal wire, it shows full. The new unit will only make the gauge show 1/2 even though the float is moved to the full position. I have included three pics, with the float rod in the empty, 1/2, and full positions. Am I not doing something wrong?
Note if you are grounding the lead to get a full reading then the resistance must go down not up. Unless you got the images backwards.
Skippydiesel
These sort of fuel gauges/sensors are, for the most part, unreliable. Yous your eyeball or a calibrated pace of dowel/dip stick 😈
ghost1
Turns out I didn't do my homework. Sensors and gauges ohm ranges have to match and I didn't research that. Thanks for responses
