Only proves that the engine will run at no load even with low fuel pressure. I regularly clean automobile fuel injectors at less than system pressure and the engines will run fine at no load idle. Pressure gauge at injector rail proves it is or isn't fuel pressure related. Doesn't hurt to check fuel volume also. If pressure is in spec, what triggers the injectors? A crank sensor? It would be hard to see a bad crank sensor without a scope, but maybe it would throw a code. The Kohler experts here could comment on that.
