Have a Z925M in the shop with a bottom seal pouring oil. JD made it where you have to pull the engine to be able to replace the bottom seal. The motion drive pulley was a bear to get off had to drill two holes in the pulley so i could make a puller to get the pulley off. When I got the engine off having to take various shield and weight off. Pulled the bottom seal out and found the lower main bushing had worked it's way down in the pan and wiped the seal out. On top of all this the idiots who designed the exhaust system mounted the muffler to the engine and then ran a base plate to the frame of the mower. When you mount a muffler to the engine and then run a support bracket to the frame of the mower it is not if it is going to break but when. Oh yes they are no the only idiots that do did this as Huster did the same thing on some of their mowers. If you are going to put a brace on the muffler put in on the engine not the frame of the mower. Just my little rant. LOL
