Father in laws Deere. It ran fine last week. It now cranks fine, won't stay running unless we spray short bursts of ether, enough to keep it running. We noticed that there was no fuel in filter. Blew out line from tank to filter, filter to fuel pump. Still have the same problem. It appears to be no fuel to carb. Replace fuel pump and pulse hose. Now it only runs if I give it a quick shot of ether and choke is fully on. Stays running as long as choke is on. Stalls as soon as choke is pushed off. Changed both spark plugs just because we had them. Without the quick shot of ether, it backfires through the carb when cranking. It doesn't seem to have any abnormal noises or mis fires when it is running. I'm leaning towards the carb causing this. Anyting I'm missing in my diagnosis? Thanks.
Mark
Mark
