You need continuity test...testing the resistance between two points. Some switches are normally open and others are closed and you need to know which one is doing what. Why don't you follow the link Bert gave to the other guy (Farmboy) on the other thread and follow thru with it? If you still have an issue with anything just come back and ask for help.
