smitty81rc
- Feb 1, 2020
- 1
- 2
I have a z225 zero turn lawnmower i bought it used and had to replace the the ignition switch. I replaced it and it fired right up i mowed for 1hr and parked it. When i turned it off the starter was still going. then it wouldn't start. so i replaced the solenoid and the starter. Now the engine will only turn over 2 rotations and stop. If i take the spark plug out the engine will turn over just fine but when i put the spark plug back in the engine will only turn 2 rotations and stop. I dont know much about engines any ideas?
