I own a Craftsman Z-turn mower,24Hp,42"deck. model 247.25001.This mower has an electric PTO switch which engages the blades.When you go Into reverse the blades disengage and reingage when going forward again.My problem Is that when I try and reingage the blades sometimes they will not reingage.I have changed out the PTO switch and checked the wiring but have the same problem.I was thinking that the PTO electric clutch becomes to hot to operate and will not engage till It cools down.Hoping someone will have an Idea on what causes this problem. Thanks Tom
