turbofiat124
- Mar 23, 2011
- 83
- 288
It is a matter of leverage.
By grabbing the blades you get a big mechanical advantage and that does make a difference.
You can not check the housings by grabbing the pulleys.
Even "professionals" like myself can miss a cracked spindle housing and many of them will look fine , untill you put a load on them when they open up.
This is why you have to pull the deck and put some serious weight on the blades to check properly.
Expect all the bolts to break off when you try & remove them.
Aftermarket spindle housings come with new bolts, Originals don't.
Check the prices , usually a complete housing + spindle + bearings is only a few $ more than the bare housing and worth doing the whole lot in one hit.
Nice clean deck by the way, nice to see some one who looks after their mower.
I already got spindle and pulley off and a new spindle on the way. This is what I ordered:
Loosening the bolts on the spindle was not as hard as I expected. I didn't even have to use any PB Blaster. The trouble was getting the pulley off. I ended up tilting the deck on it's side, putting the blade back on then sticking some screwdrivers through the holes in the spindle against the blade so it wouldn't move.
While blowing off my driveway, I take my leaf blower and blow off the top of the deck, engine, etc. before putting it in my yard barn.
Edit:
I see what you mean know about no grass buildup under the deck. I didn't notice that. I don't know why but grass doesn't seem to stick to the underside of my decks like it does on my father's. It maybe the type of grass I have (zoysia grass?).
A couple of years ago, the mount with screw that holds/adjusts the deck broke and I welded it back on. So I may have removed all the grass then.
Whenever I fix my father's mower or sharpen the blades there is about an inch of buildup on the underside. I have to use a paint scraper to remove it.
