Runs real fast, no worries then! Should mow the lawn real good! :laughing: Ok, not really. Only thing I can think of is somehow the throttle return spring is hooked up wrong. Not pulling the throttle plate (correct term :smile
closed. Suggest you check it not running and see if it's pulling the throttle plate closed. Maybe it's hooked to the right spot on the carburetor but not hooked far enough away so as to pull the spring out tight enough to closes the throttle plate? Hope that makes sense to you. Anyhoo, might be time to take a brake and come back with fresh eyes. It's amazing how that helps sometimes. Good luck and remember, you got it running! You're doing great. :thumbsup:
