NurdBurd
- Jul 8, 2018
- 1
- 3
I have a fuel leak from underneath my tractor - which means I don't know exactly where the hole is. I need to remove the fender (Repair Parts Manual, 532 44 54-73 Rev.5, Page 6, Item #37). I have already removed the four bolts (Page 17, Items #8) and the two nuts (Items #6). The back half of the fender can be raised up a few inches after the removal of these six items. The front part of the fender is located underneath the Lower Dash (Page 6 again, Item #182). I removed the right side nut (Item #194), but the bolt did not fall free from the lower side of the fender. I don't understand how the fender can slide rearward unless this bolt is removed (and its partner on the left side of the Lower Dash). I can not see the four screws (Items #36), but my fingertips tell me they are there. I don't believe I could get a wrench or socket on them for removal.
Do I have to remove the four screws (Items #36) to remove the fender so I can gain access to the gas tank? Or is there some other procedure that I need to follow? I am in need of an answer quickly because the grass is already at two feet and it is still growing!
Thank you.
Thank you.
