YTH22V46 stopped going forward and reverse,
jqpsu39
Bought it brand new, it has 6 hrs of use and it runs well. Was mowing my lawn and stopped to move something and started it back up to find it wouldn't go forward or in reverse. Nothing seems to be moving when I press the pedal. I wouldn't think anything is worn out at this point.
What I checked:
Drive belt
Did the procedure to remove the air from the hydraulic lines.
Checked to make sure lever attached to the pedal was in working order.
Any ideas?
Thanks for any recommendations.
With only six hours of use it should be still under warranty so let the dealer handle it.
What I checked:
Drive belt
Any ideas?
Stupid question, did you check the bypass valve?
On a new unit that would be the more obvious cause. Work the bypass rod in and out a few times and then make sure its all the way in. Then test it again.
If you are referring to the black lever behind the mower below the seat that moves in and out to engage and disengage the transmission, then yes, I looked up the procedure to bleed the air out of the transmission. Tried that several time with no luck.
If that is not what you are referring to please explain. I'm not sure what or where the bypass valve is.
Yes that is the bypass valve.
Thanks for all the replies. I found that the belt came off of the pully on the front drive shaft(?). It was difficult to see unless you look from a certain angle. There are two braces that come down from the frame to help hold the belt in place, therefore when I previously tried to move the belt it appeared to be working.
Thanks again and sorry for my inexperience about something so simple.
