Auto Doc's
Hello R.,
From this picture, I think the belt retainer tab is clocked in the wrong position for the larger idler pulley. Loosen the pulley partially and see if the retainer tab will align at about the 4 o'clock position. That and the tab should tab be closer to the pulley. They are spring steel, so the pulley may have to fully removed and then the tab bent and test fitted. Most of the belt retainer tabs on a stationary idler have an alignment tit that fits in the hole of the deck mount welded bracket.
