LarryC3315
- Mar 18, 2020
- 4
- 19
I took it to a guy in Rogers that works on all brands. He understood right away what was wrong and ordered the parts I need. Should be in any time now.
here you go, but it doesnt look like a separate part so youcan only get it as part of buying the whole tranny https://www.partstree.com/models/yta-22v46-960450051-00-husqvarna-46-yard-tractor-2015-07/drive-2/Must have messed up. I posted yesterday about a shop in Rogers ordering the parts I need. Turns out he was unable to find the parts. He tried with everyone he knows and no one sells any of the parts on the transmission. So, I have a mower that is in good shape every other way that I can't use. Is there anyone on here with the same model? If you could post pictures of what is there, maybe my brother can make something for me. He has a pretty fair machine shop. YTA22V46 960450051 is the model number. Now I can see what I posted yesterday.
Actually all he had was the drive belt routed wrong. See post 14 that was 6-1/2 hrs before yours. It help a lot when reading the whole thread before posting. Also post 13 contained links for servicing the CVT transaxle.here you go, but it doesnt look like a separate part so youcan only get it as part of buying the whole tranny https://www.partstree.com/models/yta-22v46-960450051-00-husqvarna-46-yard-tractor-2015-07/drive-2/
you have only 2 choices left, buy a new tranny, or buy a parts mower and take that tranny, or the parts you need from it, off to fix yours
then maybe there is still a 3rd option is someone on ebay might be selling that part you need used
and in the future remember your lawnmower transmission is weak as **** and not designed to pull anything around more the a small lawn cart with 25 lbs load in it
no he said he had parts that fell off the tranny he found in the yard and there was still missing parts he couldnt find part numbers forActually all he had was the drive belt routed wrong. See post 14 that was 6-1/2 hrs before yours. It help a lot when reading the whole thread before posting. Also post 13 contained links for servicing the CVT transaxle.
I don't mind folks trying to help but they do need read everything posted first or they just look dumb after the fact the OP posted that he got things fix. It sorta like posting to a 5 yr old thread as if it is something just posted.no he said he had parts that fell off the tranny he found in the yard and there was still missing parts he couldnt find part numbers for
thats why i posted what i did, but your need to feel superior caused you to feel the need to take shorts at others trying to help
