l008com
- May 25, 2015
- 37
- 199
So I watched a bunch of youtube videos for removing the impeller off my machine. This is so I can ultimately take the motor off and open it up because I think it overheated and melted it's camshaft. But anyway....
Multiple videos say to use a 7/16" - 20 bolt. So I go pick one up and when I go to thread it in, nada. Totally the wrong threading, although the diameter seems right.
So what's going on here? Did I buy a bolt with the wrong threading? Certainly possible someone could have put it in the wrong spot on the nut and bolt wall at the hardware store. Easy enough to check if someone can tell me what the " - 20" is. Is that like threads per inch or theads per something?
OR does my impeller just need something other than - 20 threading? Unfortunately you need this bolt to remove the impeller so I can't just bring it into the hardware store and try every size until I find one that works - which is what I normally do in a situation like this
BUT I do have a picture, maybe you guys can tell just by looking?
Assuming the "20" is the threads-per-inch, it looks like I have 19 threads per inch here. I assume that missing thread is just the perspective of the camera. So it is a -20 bolt, so I guess I need something else you think?
Oh also here's the model number(s) off the machine itself:
24A-070J799
247.77013.0
And the serial number is:
1H198G70100
24A-070J799
247.77013.0
1H198G70100
