yard man
gom11
stuck clutch after mowing stopped let set then ready to put up push clutch in would not fully release
Boobala
Sounds like a broken/missing spring issue, it would help us to help YOU !! IF you supplied us with your machines info. see EXAMPLE
GET INFO.JPG ...... click to enlarge
Remove the deck then get under an clean the underside of the debris that is stopping the clutch pedal fully releasing
