Yard Machine 3.5HP Gas Edger, Depth Adjustment won't drop enough?
c11488
I have a Yard Machine 3.5HP gas edger model# 25A-580A000 with a Briggs engine on it: 94212-0319E1.
Before I delve into fixing the engine, likely a carb replacement, I am struggling to understand why I can't seem to lower the blade enough to be below the tire levels which is needed to cut into edge of a sidewalk obviously. I know the blade is supposed to be about 9" and mine's a little over 8" but that's only 1/2" short which still should be usable or at least break the ground "plane".
From what I can see, when I drop the blade to the lowest level which is very tight tension on the arm bracket it seems to be constrained by the belt being super tight to not allow any further drop. I know I can adjust the ferule on top but nothing helps there. I double checked the belt and according to the parts should be a 31" belt, which I confirmed the existing one measures 31" on outer circumference. When I take the belt off, you can see in the picture the blade drops plenty far below ground level, but with the belt on I still have a clearance of over an inch which has my fingers beneath to illustrate. Seems like a slightly longer belt might allow more drop, but what am I missing here assuming I have the correct belt?
Thanks
Mike
No belt on it allowed to drop below ground level (wood deck of my lift table) just fine.
Lever in lowest position.
Belt is on and lever all the way down, but >1" clearance.
You notice that threaded rod? That is for making a manual adjustment when the blade wears the ends down. Pull the clip out and turn the adjust up or down to improve the depth of the current blade.
When you replace the blade, you may have to readjust so it does not cut too deep.
Thanks for the quick reply. I am aware of the rod adjustment ferule but that doesn't appear to be the constraint. Rather with the rod detached as shown in video the belt still stops the drop of the blade which seems constrained by the belt length. I ordered a new belt to verify mine is still correctly sized, but I don't think the belt is wrong either. Edit: looks like I can't upload a video here...so just another still show showing the rod detached and belt stopping it.
Better later than nothing. I have the same edger. What I did to solve the problem . On the edger there 2 metal bars that attach the front wheels. . Remove 1 bolt from each side to allow the arm/wheel connector to pivot. To do this you will have to remove the wheel axle and wheels. ( simplify swing arm with swing now with one bloy on each side holding them. If you get this . send an email and I will try and take some pictures.
I notice that there is a lot of room inside the blade shield. Could you use a new blade?
Maybe I missed it, but did this start with a new belt, suddenly start one day, gradually, or are you a new owner of this edger?
The one I have similar to that, the quill is loaded by a spring. Does the spring work on yours or is that area rusted and frozen? Meaning that as the quill is lowered the spring loads as I recall. Will have to go out and look at mine later.
