eagle86801
- Jun 6, 2017
- 4
- 25
I can't figure out why this machine isn't getting gas. I took off the carb and cleaned it out twice. drained the gas tank. It will start if I remove the spark plug and spray starting fluid in the hole . It ran fine last year after I tuned it ,I changed everything. I only use it for a small piece of lawn 30' x 8' . I can't figure out the gas issue . Thank you
