I'm having a problem with the mower deck engaging when
the deck is raised all the way up.
Ok if it is the kind that when you lower the deck and the blades come on and won't come on when in the top one or two settings then you need a new belt.
(( racing is the only sport that you need two balls ))
NEW BELT AND BLADES MIDDLE OF LAST YEAR....
Sorry all fixed now......
