rvalcarcel74@gmail.com
- Jun 10, 2013
- 1
- 1
I recently bought a used yardmachine in good shape, got it home, cut yard, put away...had to replace battery and solenoid and got it running again...it was raining and I took it out for one pass....smoke pouring out of exhaust and shut off....starts up and stops for a bit then Boggs down and smokes...I checked and oil smells like gasoline is in it....could it be clogged air filter, or blown head gasket??? Is there a definite way to diagnose the exact issue?
