Yard Dog
Scrubcadet10
Moderator
Staff member
Can anyone identify the model of Ruixing Carb used on this, i may order a carb rebuild kit, i got two of the saws in, both the same, fire up and idle die when given throttle, the dern fuel line was pretty much toast and fell apart, also going to check the muffkin for blockages.. Apparently yard dog was made by a Chinese chainsaw mfger that labeled different brands. Yard Dog model # is 50969, 45cc
Pics
Scrubcadet10
Moderator
Staff member
I've found some identical "will fit" carbs by typing in "45cc chainsaw carb" but no Kits
