vv0350
- Oct 21, 2013
- 5
- 13
My new Xt1, LT42 left front deck was catching on T posts when mowing along our long fencerows...trying to trim under the bottom strand of wire...So, I devised a skid plate, defector to bolt on the edge of the deck to eliminate the occasional "catching" when I went around the T posts...I first drew a pattern/plan and then a aluminum test of the plan. Then a light ⅛" steel plate was cut out with a saber saw. The steel plate came from a cut out that I did in the roof of a shipping container when I put a exhaust pipe in place. Anyway, once cut out I used a baleen hammer and a vise to bend the edge to match the lip on the deck. Then found two small square head carriage bolts to fasten it all in place...[
