Xt1 enduro Lt42 missing bad
grizilla
Engine is missing bad, then runs good for a few seconds, goes back to missing.
I think one of the safety switches is going bad?
Need to find wiring diagram to track it down?
Scrubcadet10
Moderator
Staff member
Could be, but first I would remove the engine blower housing, locate the ignition coil, and disconnect the kill wire. If that stops the missing, then I would say its an electrical issue. If it doesn't, probably a fuel or other issue
