I have replaced Koyler with the same engine from a Troybilt super bronco.The wiring is different..There are more wires in the connection on the Cub than the Troybilt has.Any suggestion?
Both Engine's are a Koyler 20 hp single Cyl Courage.I don't have model info right now.I pulled the good engine from a Troybilt Super Bronco.The Cub has more electronic's than the Troybilt.Wondering if I should pull wiring harness off the old engine that came off the cub and replace on the good engine.
