Xl chainsaw help, please
Old fiddler
Homesite XL chain saw - no other numbers/model/unit number/serial number
16” bar
Ran out of fuel, primer bulb cracked, replaced bulb, refueled it, it would start and die out
Replaced both fuel lines from primer bulb
Did not replace fuel line with filter on it (it held vacuum)
Did replace the fuel filter while it was apart
Replaced air filter (which was deteriorated)
Starts on primer but getting no fuel to remain running - what’s my next move, please
Fuel is mixed properly and fresh
Tiger Small Engine
16” bar
Make sure you have fresh pre-mix fuel, not stuff that has been sitting in the garage for a while. Try adjusting the carburetor and if no change, need to remove carburetor and clean. Otherwise, try to find a shop that will work on a Homelite. The downside is the labor cost on an old Homelite may not be worth it. One of the main reasons I only work on Stihl, Husqvarna, Echo, and Redmax handheld equipment.
MParr
Make sure that your pickup and return fuel lines are connected correctly.
Old fiddler
Old fiddler
Fuel is fresh and mixed correctly- I will clean the carb and see what happens
If the fuel lines were dead, betting the diaphragms inside the carb are too. Install all new fuel lines and filter. Throw a carb kit in her.
Old fiddler
Thank you - I was going to do that while it is apart when I clean the carb -
Old fiddler
I searched for a carb kit - not much success - any suggestions?
Old fiddler
Only number on the carb is an H17 26G Zama - I e-mailed them - have not heard back
