XF2500 - 60 Hard to start
nstrull
Im not complaining because this mower was just given to me. I cleaned the carb and replaced the plugs. Everything works pretty much like it should besides needing some adjusting. The only major problem i'm having is it's hard to start. I turn the key and its very slow to crank. I tried 2 new batteries and the same thing happened. Next, I tried to take the starter off and cleaned as much as i could. The only thing that will allow it to turn over a little faster than normal is to remove the spark plugs. I even tried jumping it from my truck. Another thing is that it won't do anything if i try to just jump the starter.
I have no idea what the problem is.
