X595 diesel
cpurvis
I did that but wasn't getting any fuel either so that's when I took the solenoid valve off and it started right up put the new solenoid on and the same thing
What did you have in the fuel line in place of the old solenoid when you started it up?
Gary Hensley
Nothing the plunger on the solenoid works a valve inside the injector pump to let fuel go threw or not but it won't leak in fuel out.i need to figure out were its power comes from I just hook it straight to my car battery and it went in.I wish I had a electrical print but I will just have to trace it threw the whole circuit but thanks a lot for all your help
