X500 stops after 10-15 minutes
Kwando
X500 with Kaw FS730V stops then sometimes just restarts sometimes have to wait 5 minutes. When it does start I can ussualy finish the 1 acre lawn. I have replaced the fuel filter, the fuel pump, seat switch, and have driven with the gas cap loosened still doing the same. ???
MParr
Sounds like a fuel delivery problem.
It could be trash in the fuel.
The fuel tank pickup lines could be deteriorating.
It could be trash getting hung up in the 90 elbow coming from the tank.
It could be trash in the tank shutoff valve, if you have dual tanks.
Trash in the carburetor bowl or fuel solenoid not operating properly.
bluesky
I had two problems with my X500. The fuel filter in the tank was clogged. And when I also replaced the "inline" filter, I saw some crud in the fuel hose before the filter ( where the filter slides into the hose).
