x350 - Hit Tree Root
Chad5207
Hi All - I have a new x350 42” deck. Today, I hit a small surface tree root and the tractor immediately shut off.
When looking underneath, the blade was stuck in the tree root and after starting the tractor back up, I was able to rock the tractor back and forth and loosen it from the root. The blade appeared to be slightly bent and there was noticeable vibration when turning on the PTO, so I replaced the blades.
my question is, do these machines have safety built in to immediately shut down PTO and engine when the blade gets jammed, or did I potentially damage the machine? With the new blades, It appears to working okay.
Thanks, in advance!
There is no safety shutdown for self protection, so the potential for damage is there. If it is mowing even then most likely you are fine.
Air up your tires this happens every spring. People break out their mower and don't air up the tires and the tree root, rock etc. you mower over last year plays got you.
Sometimes the flywheel key will shear but seems yours is just fine . More often on a direct drive blade opposed to a belt driven blade .
