I bought a X304 in 2003 and it's running fine with 1200 hours on it. The x304 has a 42" deck. The way the 42" deck is made, grass is lifted, cut and thrown out the discharge at a pretty good rate. The cut is generally clean and I can generally get a good cut on one pass.
I just bought a used (but essentially new) X324 with the 3-blade 48" deck and it came with a mulch attachment. The 48" deck does not cut as well as the 42" deck. I removed the mulch attachment and the entire front of the bottom part of the deck is, open. There is no channeling, or anti-blow by structure to lift and direct flow in the 48" deck like there is in the 42" deck. The cut is poor as some of the taller grass just lays down or goes uncut. Very little grass is thrown from the discharge in the 48" deck.
The 42" deck is designed for lift and discharge, while the 48" deck does not appear to be designed for lift and discharge.
Is there something I can do to the 48" deck to get it to function better, or are these decks, well, crappy?
