I have a 2012 X-ONE, 60" rear discharge deck, 23.5 HP Kawasaki FX730V. It is primarily used for cemetery service. It is one fine machine, it can mow fast or slow and its slow speed handling and response is very comfortable. X-ONEs are heavy duty commercial machines, with possibly the best maintenance schedule of any comparable unit. Although they weigh over 1,200 LBs, the fuel consumption is reasonable. Where my machine is used, it takes 2- 2 1/2 ten hour days to mow the cemetery. The unused portion of the cemetery is 5 acres and is usually hayed by a local farmer. When he isn't able to hay the field, the X-ONE gets the job and does better at it than expected. I highly recommend the X-ONE, but if you have smooth and flat areas, then you may consider a Super Z or a Super Z HD as they have a faster ground speed. My dealer has sold over 200 X-ONEs since they came out, the bulk of them with rear discharge decks and delivered to the State of Connecticut for highway dept use.
Mad Mackie in CT:laughing::biggrin::smile:
