sgkent
looking for new or used Murray / MTD / Craftsman edger quill in working condition. These typically break the weld and get replaced, but the part is NLA and not available. If in reasonable condition the part can be welded. Or maybe someone has an edger that is dead and not worth repairing but the quill is good. Typically if one looks at the parts diagram for the edger, part #321 will show as a 338070, 338070ma, 740039, or 740039ma. If you have one or think you do please snap a photo and send me a PM or a post with what you want. To remove then the old belt gets cut off, a nut gets removed from the lever that goes thru the quill shaft, the end of a tension spring slides out and the quill pulls off. It is a really common part on edgers made in the 1990's.
Thanks - Steve
Thanks - Steve
