woofer60
woofer60
I have a 3 year old john deere la125 tractor. It has a 42" deck. The right side doesnt cut the grass all the way. I looked at the spindle and the blade and they seem fine. belt seems good too. Any thoughts?
LawnBoy M
It could be that the deck became unbalanced, and that one side is cutting higher than the other side, causing an uneven cut.
Jeff
SeniorCitizen
Has the deck belt tension ever been adjusted since it was new? Your manual mentions this is to be done after a few short hours of operation and tells you how using you as a Guinea Pig for a judgment call.
If there are caked dried grass clippings under the deck, clean it.
Briana
Hey there! WELCOME to LMF!
I moved your thread to the General Mower Discussion Forum. You'll get a better response there. :thumbsup:
SeniorCitizen
Once again I didn't do a very good job but at least I have a partner now because LawnBoy M didn't either.
I'll try to do better next time but LawnBoy M is on his own. :laughing:
KennyV
Hahaha...:biggrin:
I know her comment seems to say your response is not good enough...("moved your thread to ... You'll get a better response there.")
But I don't think that's what she is really saying... I Hope:wink:... :smile:KennyV
