Repairs woodruff key keeps breaking
jcm35
Hello everyone,
I have a Craftsman riding mower lt2000. Model No. 917.273756 that's about 10 yrs old.
The woodruff key #61 (half-moon shape) for the disk brake keeps breaking. I put in new pads, spring and brake rod. The rod is adjusted to about an 1 3/4". About 10 minutes into mowing the brakes stop working and it will no longer stop.
Thanks for the help!
mechanic mark
Shearing the woodruff key on the brake shaft is very unusual. The only cause I can see is a key either loose in the shaft or the brake disc. Both should be snug.
jcm35
MechanicMark: The problem is with the brake disc not the ground drive. It's with the Dana Trans axle item #25 which holds the disc brake item #62.
Rivets" It was pretty snug when I attached it. Had to use a hammer to get everything to come together.
Gonna try and loctite the next one.
