V Vulnavia Member Joined Mar 24, 2018 Messages 34 Sep 2, 2024 #11 I have traced the wiring ( I finally found the proper wiring diagram) and will test the switch. Thanks for the advice.
P Poodlehead Active Member Joined Mar 10, 2020 Messages 68 Location College Station, TX Sep 3, 2024 #12 I had a similar problem and it turned out to be a loose negative battery cable at the engine.
V Vulnavia Member Joined Mar 24, 2018 Messages 34 Sep 4, 2024 #13 I will check and make sure it's tight. Thanks, Will
